Help
How to use WD elements SE run in  iMAC ? helpppp…
This is a plug any play drive with no software to install. It’s formatted NTFS for Windows. So at the minimum it would need to be reformatted for Mac. If you want to use in Windows and Mac it would need to be formatted FAT32. I believe that’s all you need to do. http://www.wdc.com/en/products/products.asp?driveid=675  Check the Mac compatibility.
thanks joe!
