hi i bought a sansa 200 (a 2gb) and i cant find the media converter. When i put in the instaltion disk no pop up comes up saying what do you want to install?( or should there?) mabey it already is instaled and i cant find the file?
depending on what OS you have installed auto run may not work. the easiest thing to do is to explore the cd and look for the setup.exe and run that. to explore the cd just go to my computer and right click the cdrom and select explore.
I figured it out. i put the disk in and went to my computer and explored but there was no “setup.exe” file so i searched it and ran it from there. thanks every one
