I am having issues getting the connect to acutaly “connect”. It seems it recognizes it is connected but I cant do anything. I open rythymbox It doesn’t recognize the connect. Here is my output of mtp-connect.
ry@ry-desktop:~$ sudo mtp-detect
[sudo] password for ry:
libmtp version: 0.3.7
Listing raw device(s)
Found 1 device(s):
SanDisk: Sansa Connect (0781:7480) @ bus 0, dev 10
Attempting to connect device(s)
LIBMTP PANIC: could not inspect object property descriptions!
PTP: Sequence number mismatch 2 vs expected 5.LIBMTP PANIC: could not inspect object property descriptions!
PTP: Sequence number mismatch 3 vs expected 6.LIBMTP PANIC: could not inspect object property descriptions!
Error 7: Unable to read Maximum Battery Level for this device even though the device supposedly supports this functionality
Error 1: Get Storage information failed.
Error 2: PTP Layer error 02ff: get_all_metadata_fast(): could not get proplist of all objects.
Error 2: (Look this up in ptp.h for an explanation.)
Error 2: PTP Layer error 02ff: get_handles_recursively(): could not get object handles.
USB low-level info:
Using kernel interface “usbfs”
bcdUSB: 512
bDeviceClass: 0
bDeviceSubClass: 0
bDeviceProtocol: 0
idVendor: 0781
idProduct: 7480
IN endpoint maxpacket: 512 bytes
OUT endpoint maxpacket: 512 bytes
Raw device info:
Bus location: 0
Device number: 10
Device entry info:
Vendor: SanDisk
Vendor id: 0x0781
Product: Sansa Connect
Vendor id: 0x7480
Device flags: 0x00000000
Configuration 0, interface 0, altsetting 0:
Interface description contains the string “MTP”
Device recognized as MTP, no further probing.
Device info:
Manufacturer: SanDisk
Model: Sansa Connect
Device version: 1.1
Serial number: 00350000106c8075ac25bcb80300b7b8
Vendor extension ID: 0x00000006
Vendor extension description: microsoft.com/WMDRMPD: 10.1;
Detected object size: 32 bits
Supported operations:
1001: get device info
1002: Open session
1003: Close session
1010: Reset device
1014: Get device property description
1015: Get device property value
1016: Set device property value
1017: Reset device property value
1004: Get storage IDs
1005: Get storage info
1006: Get number of objects
1007: Get object handles
1008: Get object info
1009: Get object
100b: Delete object
100c: Send object info
100d: Send object
9801: Get object properties supported
9802: Get object property description
9803: Get object property value
9805: Get object property list
9804: Set object property value
9807: Get interdependent property description
4001: Unknown (4001)
9810: Get object references
9811: Set object references
9101: Get secure time challenge
9102: Get secure time response
9103: Set license response
9104: Get sync list
9105: Send meter challenge query
9106: Get meter challenge
9107: Get meter response
9108: Clean data store
9109: Get license state
910a: Send WMDRM-PD Command
910b: Send WMDRM-PD Request
100f: Format storage
9806: Set object property list
Events supported:
None.
Device Properties Supported:
0x5001: Battery Level
0xd402: Friendly Device Name
0xd101: Secure Time
0xd102: Device Certificate
Playable File (Object) Types and Object Properties Supported:
b104: Unknown(b104)
b901: WMA
b982: MP4
ba03: Abstract Audio Album
ba05: Abstract Audio Video Playlist
3000: Undefined Type
3001: Association/Directory
3008: MS Wave
3009: MP3
3801: JPEG
Special directories:
Default music folder: 0x00000000
Default playlist folder: 0x00000000
Default picture folder: 0x00000000
Default video folder: 0x00000000
Default organizer folder: 0x00000000
Default zencast folder: 0x00000000
Default album folder: 0x00000000
Default text folder: 0x00000000
MTP-specific device properties:
Friendly name: (NULL)
Synchronization partner: (NULL)
libmtp supported (playable) filetypes:
Microsoft Windows Media Audio
MPEG-4 Part 14 Container Format (Audio+Video Empahsis)
RIFF WAVE file
ISO MPEG-1 Audio Layer 3
JPEG file
Unable to acquire device certificate, perhaps this device does not support this
Error 2: PTP Layer error 02ff: get_device_unicode_property(): failed to get unicode property.
b982: MP4
3008: MS Wave
3009: MP3
3801: JPEG
RIFF WAVE file
JPEG file
b982: MP4
3008: MS Wave
3009: MP3
3801: JPEG
RIFF WAVE file
JPEG file
ERROR: Could not close session!
OK.
ry@ry-desktop:~$ b982: MP4
bash: b982:: command not found
ry@ry-desktop:~$ ba03: Abstract Audio Album
bash: ba03:: command not found
ry@ry-desktop:~$ ba05: Abstract Audio Video Playlist
bash: ba05:: command not found
ry@ry-desktop:~$ 3000: Undefined Type
bash: 3000:: command not found
ry@ry-desktop:~$ 3001: Association/Directory
bash: 3001:: command not found
ry@ry-desktop:~$ 3008: MS Wave
bash: 3008:: command not found
ry@ry-desktop:~$ 3009: MP3
bash: 3009:: command not found
ry@ry-desktop:~$ 3801: JPEG
bash: 3801:: command not found
ry@ry-desktop:~$ Special directories:
bash: Special: command not found
ry@ry-desktop:~$ Default music folder: 0x00000000
bash: Default: command not found
ry@ry-desktop:~$ Default playlist folder: 0x00000000
ry@ry-desktop:~$ Default picture folder: 0x00000000
ry@ry-desktop:~$ Default video folder: 0x00000000
ry@ry-desktop:~$ Default organizer folder: 0x00000000
ry@ry-desktop:~$ Default zencast folder: 0x00000000
ry@ry-desktop:~$ Default album folder: 0x00000000
ry@ry-desktop:~$ Default text folder: 0x00000000
ry@ry-desktop:~$ MTP-specific device properties:
bash: MTP-specific: command not found
ry@ry-desktop:~$ Friendly name: (NULL)
bash: syntax error near unexpected token (' ry@ry-desktop:~$ Synchronization partner: (NULL) bash: syntax error near unexpected token
ry@ry-desktop:~$ libmtp supported (playable) filetypes:
bash: syntax error near unexpected token (' ry@ry-desktop:~$ Microsoft Windows Media Audio bash: Microsoft: command not found ry@ry-desktop:~$ MPEG-4 Part 14 Container Format (Audio+Video Empahsis) bash: syntax error near unexpected token
ry@ry-desktop:~$ RIFF WAVE file
bash: RIFF: command not found
ry@ry-desktop:~$ ISO MPEG-1 Audio Layer 3
bash: ISO: command not found
ry@ry-desktop:~$ JPEG file
bash: JPEG: command not found
ry@ry-desktop:~$ Unable to acquire device certificate, perhaps this device does not support this
bash: Unable: command not found
ry@ry-desktop:~$ Error 2: PTP Layer error 02ff: get_device_unicode_property(): failed to get unicode property.
bash: syntax error near unexpected token (' ry@ry-desktop:~$ Error 2: (Look this up in ptp.h for an explanation.) bash: syntax error near unexpected token
^Abash: 3009:: command not found
Message Edited by CanadianLinux on 06-28-2009 02:14 PM
