Help with my passport, files turned to DB3/4
We had a lot of data on wd “my passport”, it was connected to a new device, and sonce then we can only see a list of DB3/DB4 FILES, thanks for your help!
I don’t understand your question. Are you saying the “new device” erased your drive and put its own files there? If so, what do you want to do? get your old files back? Probably not possible without Data Recovery software.
I wasnt sure what happened, thought maybe the old files just transformed in some way.
So you say i am out of options now and no way to recover it? Or is there any wwy to go back?
Given those file names, I’m wondering: Did you plug this into a DVR which deleted the files?
Unfortunately yes… anything i can do to save the files?
My only suggestion would be to use recovery software.
