Help with a SanDisk 16 GB 60MB/s UDMA compact flash! I shot about 200 pics (fine res) with my Nikon D700 on this flash card, then loaded it onto a reader and my computer picked it up and showed the images. I looked at a few by clicking on them and then closing the window and clicking on another. Then everything disappeared and it said to Format the Flash Card. When I put the card back in my camera, it also said the flash card needed to be formated. I did not format the card because I have really good pics that I cannot duplicate on that card. Is there any solution?
What OS you’r using ?
you can use Sandisk RescuePro and RescuePro Deluxe,
that came with you’r product,
After you recover your data, you can reformat your memory card or flash drive and use it again.
http://kb.sandisk.com/app/answers/detail/a_id/4985
