I have a netbook. it’s the HP 2133 and it operates on vista. I wonder if Windows 7 home premium will be okay for it?
Message Edited by sansafinder on 10-04-2009 08:44 PM
if vista runs on it 7 should not be a problem. it actually takes less resources than vista
Actually it works fine but vista slows it down a little and takes up too much processor. but i guess i’ll try it. Also is the view compatible with 7?
i was able to install win 7 on aspire one 110. this are the specs:
atom 1.6
intel graphics
512 RAM
8GB SSD
after adding a GB of RAM, it’s running silky smooth…
yes the view is compatible with win 7
I agree.
Ok my specs are:
2GB RAM
120 hard drive
VIA C-7 processor.
you have to download the compatibility checker from the microsoft side to check against your laptop hardware, If it completed without error than you can install windows on your HP 2133.
