Hi guys,
I recently purchased a WD Elements SE 750GB EHD. The unit has 2 days of use. I am running a 15 MBP 2.4GHz Intel Core 2 Duo 2 GB.
I partionited the drive to be Mac compiiant and transferred approximately 450GB of personal media to the drive. It worked perfectly fine on day one. After heading to bed, the following day the drive will not mount, it isn’t being found in disk utility and it isn’t being found in the USB drives. The drive turns on and the light display flashes with the spinning sound occuring.
I have another WD Elements drive and a Seagate. Both work fine. I’ve tried using the different USB connection all to no avail.
Can someone help as I’m majorly pissed off right now?
Thanks in advance.
