Had no problem doing the backup for the first time - the cruzer had an option “use this drive for backup” and I just had to click on it. Now, I don’t see this option and I need to backup in order to install new Windows software. Can someone help please? Thank you in advance.
STEP 1 - Download the Backup (U3 version) application and save to your PC.
NOTE: There are instances where Internet Explorer browser might rename the file with a .zip extension, rename the file back with a .u3p extension
STEP 2 - Run the U3 Launchpad to install
- Click on the U3 icon
- Click Add Programs and select Install from My Computer
3. Navigate to the Cruzer backup application downloaded in STEP 1, select it and click Open - Click Next to start installation
- Click Done once installation finishes
