Help? quick, extended and write zeros failed!
i need some advise. This is the history of my disc
  1. RAW after working normally (lucky that i could recovered the information)
  2. Formatted in NTFS, access OK after that but with very slow writing speed
  3. i run WD DAta Lifeguard Diagnostics: quick, extended and write zeros failed!
**bleep**!
I need to recover my disk! help!
If the quick and extended test failed, this means the drive is defective and needs to be replaced. If it is still under warranty you can create a RMA.
How to get an RMA, (Return Merchandise Authorization) or replace a defective product under warranty
It may be possible to still extract the data utilizing data recovery software. If you do a  web search for  Data Recovery  it will yield plenty of data recovery software options.
thanks but i have not warranty.
any sugestions?
