Sansa Media Converter won’t transfer my videos over to my sansa e250 because it says that there isn’t enough space. The videos is only 7.4 MB and I have over 100mb available. What is going on?
Thank you!
Thank you!
Ok so i tihnk i might have found your problem,
make sure you are downloading the OFFICIAL software that can be found here http://www.sandisk.com/driverdownload/download.asp?driverId=184
if that still doesn’t work download the firmware updater which updates your software and mp3 player
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
These two links work on both Windows Vista and Windows XP Operating Systems
if that does not work, message me
