Hello all,
I need some help to recover data from an old external My Passport HDD form 2006. The case broke a long time ago and back then I tried to extract the HDD with hopes of connecting it with an adapter. However Was unfamiliar with the conector (ATA-100? If I’m correct) and back then i stoped trying to recover it.
However now I would really love to try and recover the memories from that HD and I would like to find the correct conector to plug it and access the data.
The model is:
WD 12000UE - 00KVT0
WD Scorpio
July 2006
S/N: WXE606126509
What is the adapter I need to plug the pins to a SATA or USB ?
Thx for your help !!
