SO I DOWNLOADED THE VIDEO I WANT AND DOWNLOADEED MEDIA CONVERTOR, BUT I TRY SAVING THE VIDEO AND TRY TO CONVERT IT AND THE DOCUMENT OF THE VIDEO DOES NOT APPEAR WHAT DO I DO?
IT SAYS SOMETHING ABOUT FORMAT CANNOT BE RECOGNIZED
Could you repeat that? I’m not sure what you are asking.
After plug in the Connect and starting SMC, you then add the video files in SMC and hit convert (which converts and transfers to the Connect).
If you want to save the converted file to your hard drive, the only way I know is to unplug the Connect while the video is converting. You will find the converted file in the SansaMediaConverter folder under mydocuments folder.
Oh I see. I’ve gotten that on a couple .wmv files. I guessing they aren’t formatted properly, although I think I could play them in WMP.
Ssssh.
What is the format of the video?
