my dad bought me a sansa 2GB clip and it only works on xp and vista… but i hooked it into my pc that is windows me and it says connected but i need drivers.
how can i find drivers for it
i need
usbstor.sys
usbstor.inf.
system\vmm32.vxd
system32\drivers\usbntmap.sys
system32\drivers\usbstor.sys
ntkern.vxd
i done posted this question on other sites
Which version of Windows are you using?
Yue
Sounds like it’s a USB issue on the computer side. Do other USB devices, especially USB storage devices, work?
See if you can reinstall the USB drivers.
You may want to follow this http://www.pcanswers.co.uk/tips/default.asp?pagetypeid=2&articleid=16484&subsectionid=616
tutorial if you’re unsure how.
Hope this helps, good luck!
Yue
Short answer: Windows ME is not a supported firmware. But perhaps others will be able to assist.
Did you try connecting in MSC mode? (Either selecting MSC under Settings/USB; or putting the player into hold and then pressing the center button down WHILE connecting to your computer.)
