Help! Help! My computer this time can not find the Sandisk M240, but before it was ok. What can I do?
After I unplug the MP3 from computer and turned on it, it will show " Finalizing Update" very very long time. What is the problem?
Hi!
try taking out the battery for a couple of minutes… and then put a new on in. Also try putting the hold switch on and connecting to pc, if ti shows try reformatting.
