Hello, I was looking for some help on fixing my hard drive here is the issue. I plugged the external hard drive into my Nvidia shield it changed the type and formated it to read it once that happened all the data was lost. I had to reformat it back to the original on the shield now when I plug it into my PC it says that there is something wrong with the hard drive and I go and repair it does its a thing then freezes at the end. I can look at files on it but when I upload anything it crashes my pc any tips? do I need a new hard drive now?
Go to Disk Management and check what is the status of your drive. I believe you will get help from it.
