Hello, I just bought a 4 gb fuse. I plug it into my computer and it comes up that it is recolgnized, I can click to open folder but if I click to open the internal memory to add songs the folder freezes. If I tell it to open into rhapsody and try to click and drag from my library, like it says, it freezes. If I open windows media 11 and click on sync it freezes. The fuze connects to the computer, system says it’s working properly, I updated the firmware but I’m not able to put anything onto it! Any suggestions? I meet requirements, I’m running WinXP SP3, Win Media 11, and am hooked in through the usb. I don’t know what I’m doing wrong. ![]()
This problem was solved. It was the USB port I was trying to use. Once switched to another port it worked fine.
