My new secondary drive is identified in the Bios of my X570 Aorus Elite Wifi, under M.2 and in the boot sequence, also AMD RAIDXpert2 is off. Windows device manager does see the drive but disk management does not. I would like to partition and use this drive for general file storage. Can this be done without Disk management, if not what troubleshooting should I do to get it working normally?
I tried this initially but must have done it incorrectly or non-completely. I removed the previous pool and created a new one. However I discovered that the new pool would only generate with simple (No resiliency) selected. As soon as I chose this option and initiated the pool creation everything was working.
Thanks JasManZN
i seen that pool myself and wondered if that was a work around but i still beg the question, why isnt windows detecting it as secondary storage device? btw thanks for the info it functions fine just still curious lol
