im haveing trouble accessing my portable hard drive
If your hard disk drive becomes unresponsive then there are chances that your drive may become RAW or inaccessible. There are various reasons for this issue such as BIOS settings, USB data line, USB interface voltage variability, drive hidden issue or compatibility issue, etc.
Whatever be the reason, the end result is data inaccessibility or data loss.
You can try the below options as a solution for this issue:
- Establish a connection between another system and the USB Data Line to verify whether it is broken or not.
- Make sure the system and motherboard are compatible with each other.
- Verify whether the USB interface voltage is up to the mark or not.
- Use Disk Management to unhide the drive.
- Ensure USB is enabled in the Operating System as well as in BIOS.
If you wish to recover data from a faulty or unreadable hard disk drive, then you can do that with the help of data recovery software. Here, I recommend you to use Stellar Data Recovery Professional Software, it enables the user to recover their lost or deleted data from corrupted, unresponsive, or accidentally formatted drive and even recover lost partitions of the drive.
You can also check out the below link, hope it will help you out:
What is RAW Recovery and How to Recover Data from Raw Drive?
Cheers!!!
Im still hating trouble recovering everything on my portable hard drive.
