Can someone confirm what type/level of hardware encryption is used on this drive? The product literature only says that it has “256-bit hardware-based encryption”
Is it AES 256 bit or something else?
Thanks,
S
Thanks,
S
AES 256 bit
If you examine LBAs 0 and 1 with a disc editor, you may see a repeating pattern of encrypted zeros. If this pattern repeats every 16 bytes, then I would think that this would suggest 128-bit encryption.
HxD - Freeware Hex Editor and Disk Editor:
http://mh-nexus.de/en/hxd
DMDE (DM Disk Editor and Data Recovery):
http://softdm.com/download.html
