Hard drive formatted and I need to use it again. model WDBU6Y0020BBK-EB
after formatting, just use it.
have an issue ? provide a lot more information about the problem as people here aren’t mind readers.
If your hard drive is formatted and you need to use that again then you can easily do that. There is no harm in that, however, if you wish to use the same data which was there before formatting the drive then you need to use data recovery software to recover your lost/deleted data from a corrupted or formatted drive.
Hi, Joey
Yes, but after formatting ( i idid 4 a play 4) , but my laptip “Can´t see” the hard drive. In the other hand, i never put any data. What do you think i need to do?
Thanxs
Yes, but after formatting ( i idid 4 a play 4) , but my laptop “Can´t see” the hard drive. In the other hand, i never put any data. What do you think i need to do?
Thanks
