Hello everyone.
Does anyone knows if the sansa taketv supports greek fonts??
I just bought it but i m not able to see them allthough the video plays fine.
Is there any settings or any update i can change?
Thank you in advance
Hello everyone.
If your subtitle do not display correctly on the screen, check that the selected language domain is correct and, if necessary, change it. If you don’t have greek subtitl,e you could use subtitlecreator to create one with your greek fonts. The language of the subtitle is determined according to the subtitles file. The subtitle font defines the language domain to use when displaying the subtitles on the screen.
