Going to Spain in June. Does anyone know if the Sansa Clip+ compatible with their electricity which is 220V?
The Clip+ charges off of USB, not mains power. Putting anything above 5v into it will destroy the player. What charger are you using with the player?
I have plugged it into the wall using an iPhone adaptor and it charges fine. No damage or it didn’t fry it. I can also use a computer in Europe and I think it will adjust to 120 volts. Most all computers in Europe can handle dual voltage.
Yep. It’s because the Clips use “USB power”–anything (such as a a PC or a USB adapter) that provides a USB connection should provide the power in a form fine for the Clips.
