# G-speed shuttle xl thunderbolt 3 device not found
**URL:** <https://forums.sandisk.com/t/g-speed-shuttle-xl-thunderbolt-3-device-not-found/410922>\
**Category:** G-SPEED & G-SAFE SSD\
**Created:** [October 5, 2018, 4:04pm UTC](https://forums.sandisk.com/t/g-speed-shuttle-xl-thunderbolt-3-device-not-found/410922 "2018-10-05T16:04:05Z")\
**Posts on this page:** 6\
**Page:** 1
<div class="post-metadata">
**Author:** ![emonuele1](https://avatars.discourse-cdn.com/v4/letter/e/d6d6ee/32.png) [@emonuele1](https://forums.sandisk.com/u/emonuele1)\
**Post date:** [October 5, 2018, 4:04pm UTC](https://forums.sandisk.com/t/g-speed-shuttle-xl-thunderbolt-3-device-not-found/410922/1 "2018-10-05T16:04:05Z")
</div>
i INSTALLED DRIVERS FROM G-SPEED TB3&TB2 Shuttle WinDrv\_Installer\_V6.2.0.6\_WHQL-8
Rebooted and connected the drive.
Installed G-SPEED\_Software\_Utility\_200520028
I can’t see the device in create and format partitions,
The device cannot be found in G speed software utility
I see the device via intel thunderbolt software ver 17.2.71.250 connected at port 1
and the device show up G-Technology, G-SPEED Shuttle XL Thunderbolt 3
All the disks have heavy activity.
P.S. Is the first boot of the unit.
Please help.
**Author:** ![Rydia](https://sea2.discourse-cdn.com/sandisk/user_avatar/forums.sandisk.com/rydia/32/15083_2.png) [@Rydia](https://forums.sandisk.com/u/Rydia)\
**Post date:** [October 5, 2018, 4:18pm UTC](https://forums.sandisk.com/t/g-speed-shuttle-xl-thunderbolt-3-device-not-found/410922/2 "2018-10-05T16:18:28Z")
</div>
As long as you have allowed the device in the TB software from intel it should be able to pass through. Make sure the intel software is the most recent version as well from your motherboard.
Check Device Manager and see if it shows any devices needing drivers, sometimes you just have to go to the storage controller that is waiting there and force it to look for drivers and it will find the ones that are there. Otherwise you point it directly to the drives in C:\Program Files (x86)\G-Technology\
**Post date:** [October 5, 2018, 6:47pm UTC](https://forums.sandisk.com/t/g-speed-shuttle-xl-thunderbolt-3-device-not-found/410922/3 "2018-10-05T18:47:02Z")
</div>
Hello and thank You for the Quick reply.
I have latest version for Intel Thunderbolt driver and motherboard BIOS (Asus x299) i have latest drivers from g-tech and latest applicati in version.
Do You have any more suggestion?
**Post date:** [October 6, 2018, 6:06am UTC](https://forums.sandisk.com/t/g-speed-shuttle-xl-thunderbolt-3-device-not-found/410922/4 "2018-10-06T06:06:48Z")
</div>
Searching in the forum i found another thread with the same problem, how did You solved that problem?
> [@Asus Prime Deluxe x299 w/ ThunderboltEx 3 card not working w/ G-Speed Shuttle 32TB](https://community.wd.com/t/asus-prime-deluxe-x299-w-thunderboltex-3-card-not-working-w-g-speed-shuttle-32tb/221879):
> I’m trying to get a 32TB (24TB in raid 5) G Shuttle to function as main storage for Macbook Pro (2017) and a custom PC with an Asus Prime Deluxe x299 motherboard with a Thunderbolt x299 expansion card. I know I have to format in exFat, and that I cannot connect both computers simulatenously. The G-Shuttle works with the Macbook Pro when connected w/ included Thunderbolt 3 cable. However, when plugged into the ThunderboltEx 3 Asus expansion card on the PC, it does not work. I believe it is a p…
**Post date:** [October 9, 2018, 1:40pm UTC](https://forums.sandisk.com/t/g-speed-shuttle-xl-thunderbolt-3-device-not-found/410922/5 "2018-10-09T13:40:52Z")
</div>
As you can see in that response it wasn’t solved on the forum and we had asked them to contact us.
The final mention was the same I had given you which was to check the device manager for missing devices to be installed/updated. You didn’t respond to that mention other than to say you had the latest intel drivers.
Please call in to our support for a more direct hands on approach. 888.426.5214 of US support.
**Author:** ![leon\_1](https://avatars.discourse-cdn.com/v4/letter/l/ac8455/32.png) [@leon\_1](https://forums.sandisk.com/u/leon_1)\
**Post date:** [February 25, 2020, 3:45pm UTC](https://forums.sandisk.com/t/g-speed-shuttle-xl-thunderbolt-3-device-not-found/410922/6 "2020-02-25T15:45:44Z")
</div>
Same issue here…
