For the past couple of days, everytime I insert a SD into My Fuze it freezes ona the Refreshing Database screen and will not move at all, does this mean that my reader is broken now, or could it be something else?
This is likely a result of “bad” tag encoding. To resolve this, search the forum for “MP3Tag”, and follow the instructions you find to change the tags to ISO 8859-1 format.
Also, what class card are you using? Sandisk’s players have been well-known for having problems with any class higher than 4.
Check this thread out.
http://forums.sandisk.com/t5/Sansa-Clip-Zip/What-is-MP3Tag-and-how-to-manage-it/td-p/245572
