Hi all! Does anyone know how to activate lineout support on rockbox? Or, may be, lineout never will be work on rockbox? If so then this ■■■■■…
I didn’t know the Fuze had a line out? Unless you’re talking about hooking up the headphones jack to a stereo. In that case, you should be able to hook it up and crank up the volume all the way – but of course, turn down the volum before hooking up the headphones/earbuds again.
Fuze have a true line out. Line out work perfect with original firmware and DIY lineout cable.
Hmm, did not know that, even after using the Fuze for so long. I wouldn’t be the best person to help, then, as this is “uncharted water” for me.
A better place to look for (or ask) this would be www.rockbox.org.
And if the answer is no, then be sure to share the “this ■■■■■” comment; they _ love _ that over there.
