Regularly, but at random, the screen is garbled - not blank, but messed up. Words like ‘Connected’ can appear exactly, but backwards. There can be either vertical or horizontal streaking like what we used to call ‘snow’ on a TV. Icons like the music fader can be doubled. Other times, the screen is normal and works normally. The Fuze is about 3 years old and I am wondering if this is just a weak battery problem?
Doesn’t sound like it. Sounds more like it’s time for a new player. Of course you can always try re-applying the firmware. It might help; it might not.
I have reloaded firmware, but problem remains - unpredictable and random. I was thinking of replacing battery on a chance, but will probably just replace whole unit. I did run CHKDSK /F on the player also, but found no errors. Thanks.
You think the Fuze would fit in the slot?
Sure it would. After all we all know how much better the Fuze is when it’s extra crispy!
:smileyvery-happy:
