Which one is better and has fewer problems?
Fuze or Fuze+? Fuze.
Fuze+ or Clip+? Clip+
Fuze or Clip+? You want to see video and album art and slightly longer battery life? Fuze. If you can still find any.
No? Clip+
Album art, but no video? Clip Zip.
I mainly use my MP3 player for music don’t really care for album but slightly longer battery life. I wanna know what’s the difference beween the two when comes to battery life. you make it sound like the Fuze and Clip+ are about the same. Is this true?
Depends a lot of your usage habits, like how often the screen is on and how long it is on. Skip songs a lot? More backlight use, shorter battery life.
The Fuze is a larger device and threrefore holds a larger battery so no, they are not the same in battery life between charges.
Real life guestimate?
Clip+: 7-10 hours.
Fuze: 10-15 hours.
YMMMV.
For what it’s worth the Clip+ is really cheap at this point–especially because it has the microSD slot, so the built-in memory size is not so relevant.
4GB for $31,
Do not buy the Fuze+.
DO. NOT.
Fuze not Fuze+
Go with Clip. It’s so much handy and easier to operate. At least that’s just me. ![]()
