Anyone knwo why my Fuze always refreshes its database after charging? Is it supposed to do this?
Perhaps there may be something wrong with the file mtable.sys on the player? Perhaps next time you connect the player to the pc, delete this file, then the player will recreate it from scratch after it is disconnected from the pc.
Thanks very much for that - worked a treat.
