Since I upgraded to 01.01.22, my fuze crashes (stops playing and needs ‘hold power switch’ reset) at the very moment the backlight turns off. I observed that
it’s actually backlight related, if I keep pressing some keys to make the backlight stay on, everything is fine. Stop pressing keys, wait 15s -> crash
it doesn’t happen with all mp3 files. Some do work, many don’t. I didn’t yet find out which difference between the files triggers the crash
after downgrading to 01.01.15a or 01.01.11a, the fuze works fine, again
it seems like 128kbps mp3s trigger this behaviour, while 160k or 190k encoded files don’t. (took the same mp3 and reencoded it using lame 3.98.8, using different bit rates. only the 128k file triggers the crash. vbr (-V2) works fine, as do 160k or higher encoded files.
after playing one ‘working’ mp3, the ‘bad’ mp3s start to work as well, so to trigger the bug, one has to play a ‘bad’ mp3 as the first one after turning the player on
BTW this is a 8GB sansa fuze, v1.
To make sure this behaviour is not caused by a corrupt filesystem or similar, I did a factory reset and reformatted the device, just uploaded a single mp3 (MSC mode), and was able to reproduce the crash immediately.
