Fuze Battery Meter on Unit vs. on computer
Hello:
I notice on my Fuze that the display showing remaining battery life on the unit vs. what it says plugged in on My Computer does not agree.
For an example, if my Fuze says 31%, if I plug it into my computer to, it will say (on my computer screen) that the remaining charge is approx. 60%.
Which is right?
Thanks,
Steve/OH
headbeep@msn.com
@morgan841 wrote:
Hello:
Which is right?
Thanks,
Steve/OH
headbeep@msn.com
I trust the one on the Fuze more. What you see on the computer isn’t accurate because the battery is receiving charge while it is connected. If you have a wallcharger, the same principle applies…the battery percentage will be higher if the wall charger is plugged in.
Thank you for the reply.  Makes sense!
Steve
Kettering OH
