If you lose your USB connector can you use an Ipod connector. The connector will fit in the Fuze. I just don’t know if it will damage the device.
no, ipod cables can not be used.
Any other connector, except thos designed for a Fuze will damage your Fuze. At least that’s what others have said. So I’m not going to ever try it.
If you need another USB connector for your Fuze they do sell them separately. I bought 2 extra off amazon to have on hand (one at work, one at home and my orignal with me for my car or whenever I need it). They were about $4 each, so that’s why I got them.
Only if you want to fry your new Fuze! The connector is similar and you can force it to fit, but the power is shunted through different pins, so
DON’T DO IT!!!
Wow $4.00 bucks cool. Thanks for that tip a great idea to keep one at work too. Thanks a lot. Glad I did not try to charge it with an Ipod connector!!![]()
