earlier i was using my fuse, when it just shut off for no reason;
it wouldn’t turn back on, or charge, or connect to my pc.
eventually i tapped it a few times and it came on. What part of the unit could
cause these symptoms?? even if the power switch is locked off it should still connect
to the pc, so it doesn’t seem like it would be that. maybe the connection to the
battery is at fault? If i hadnt thrown away the box i would
just return it to newegg, but alas…
