I guess the “Albums” folder is there for a reason. I don’t see any mention of it in the manual. Currently my Albums’ folder contains one .alb file
g
g
Most likely created by WMP. The .alb file(s) you see in that folder should be 0 bytes in length as there is no accompanying album art jpegs stored on the Clip. I deleted my albums folder and the Clip showed no ill effects, just did a “refresh database” when I unplugged it. It didn’t recreate the folder, either.
Message Edited by PromisedPlanet on 01-31-2008 08:48 AM
The Albums folder is for putting albums in!
That’s what I put my music into rather than the Music folder.
I was assuming the folder name meant what it said
just no mention of it in the manual, just to put songs in the Music folder.
I think you are right there PP as I did have a play with WMP at one stage.
I gave up on playlists in the MTP mode, didn’t seem to be able to get them right, one folder that had 26 songs in it would only show 11, I also had a problem with getting the correct order songs played in, even though they were sorted correctly. Swapped to MSC mode which doesn’t seem to have any problems apart from a longer time to refresh the database.
You may also want to try MediaMonkey. I’ve been using it for a while with my Sansa Clip, no problems.
