Frozen
My sansa connect has had trouble in the past with connecting to my laptop. Several weeks ago i learned that if I completly shut the unit down an let it reload its defaults it would work. Tonight I tried to do this and the connect froze. Is shows a blank screen with the word SanDisk in the center the blue circle around the wheel is lit up but thats it what can I do? Is this common? Also I dont know if it matters but I just added a microSD card.
My suggestions:
1 Try and see if it boots with the SD card removed.
2 Do you have the latest firmware?  It is required for SDHC expansion memory.  The latest firmware is 1.1.1.5037r.  To see which version you have go to Settings>Info>Software Versions.  If you need a firmware upgrade, establish a WiFi connection, and it will download and install in 20-30 minutes.
3  You may need to run the Recovery Tool.  Get it here:
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
Message Edited by GnisiBrianJ25us on 12-29-2007 07:42 PM
Message Edited by GnisiBrianJ25us on 12-29-2007 07:43 PM
That is great recommendations.
Also, If it is completely hung you can hold the power button for 30 seconds. It will try a restart.
