Does anyone know how to convert a music from iTune format to Media player? I bought all these musics from iTune and now I have a Sandisk and like to add some of those songs to my SanDisk.
Thanks for your help,
Shakeb
Shakeb
i dont know of a way, but i know it would reqiuire you to strip the license.
I wouldnt be suprised if there was tools to do this sorta thing in this day and age though.
You use iTunes and convert them to mp3.
Thank you very much, it appears I have to create a CD with Mp3 format, is this right? At Window media player I can create mp3 songs right on the window media player and dont have to burn a CD.
shakeb
There is a converter built in to iTunes.
Roger that - i tunes does have a convert to MP3 option…
Yes it does, but does not let me to convert it to mp3. The message " could not be converted because protected files cannot be converted to other formats. OK"
Not sure how to unprotected. Is it protected by iTune? If that is the case then to my opinion it is illeagle because I paid for those musics and I should be able to do anything I want to do with them.
