Okay, so I’ve had my mp3 player since Christmas, and it’s been working great ever since. But last week I started having problems with it. It would turn off on its own (while it had a full battery). Then the screen started to mess up. Letters would be missing from the titles of the song, kind of like “Alie b ily Aln”, which is supposed to be “Alfie by Lily Allen”. The music wouldn’t play either. What’s going on?
You should format your player and reload the songs. If you don’t have the songs on your computer, copy the songs from your player back to the computer, to salvage the ones that are still working, before you format.
Okay it turned on but it’s really messed up. It still turns off on its own. The letters are still missing from the titles of the song. What do I do now?
@jkl wrote:
Also, whenever it does turn on, whenever it says Building database, it takes sixteen times before it is actually finished building the database.
If formating the player did not hlep, you might want to try updating the firmware. I suggest using the Sansa Firmware Updater. If that doesn’t work, then try it as written in this thread.
Hi. I don’t mean to seem negative or anything but, I’m fairly annoyed by the most obvious change between the 1GB mp3 player and the 2GB mp3 player, concerning the GoList. See, my previous version (the 1GB mp3 player) held 250+ songs in the GoList, however my new 2GB version can only hold 50 total in the GoList. Is there ANY way to modify the GoList settings so that it can hold MORE than jsut 50 songs in it? Because I have a lot of songs that I REALLY like and jsut having a few of them ruins the entire point of making them a playlist. Thanks.
