Freeware Lotus Notes to PST Converter Software
If you are looking for the Lotus Notes Recovery Software then just download the **[ATS Lotus Notes Recovery Tool] that has excellent and advanced features. It effectively repairs corrupted/damaged NSF files and safely restore data from single or multiple NSF files at a time including – emails, tasks, notes, calendars, deleted emails, journals, contacts, journals, drafts, and many more. You can easily preview your recovered NSF file data by using Preview features. The software convert NSF file into various file formats – PST file, EML, EMLX, PDF, HTML, ICS, CSV, vCard files and other file formats. It is capable to directly migrate NSF file into cloud-based application – Live Exchange Server & Office365 accounts. The software helps the user to easily split oversized NSF file into several small resultant PST files as per user needs by folder, size and date ranges. With the help of this recovery tool, the user can export any large size NSF file to PST and other file formats.
Without any trouble, you can comfortably export Lotus Notes NSF file data into PST file format successfully through the help of ATS NSF to PST Converter Software. The following inbuilt features of this toolkit are listed below –
• It quickly recovers lotus notes mailboxes from the highly corrupted, damaged and password-protected NSF file.
• Eligible to recovers permanently deleted or lost once lotus notes items without any trouble.
• Safely convert single or multiple NSF files into PST format without the installation of Microsoft Outlook program.
• Convert NSF file into different file platforms – PST, vCard, EMLX, ICS, EML, HTML, CSV, MSG, MBOX files, and many more.
• The software enables you to directly import NSF file data into Office365 & Live Exchange Server.
The ultimate resolution to convert Lotus Notes NSF to PST file type is by using a tool like eSoftTools NSF file converter. It is easy to use and does not require technical knowledge. The user can select as many items from the mailbox as many are needed. Any element can be selected which may include emails, notes, contacts, calendars, etc. Before making a conversion, the user can have a look at the content of that element and hence makes the selection of items much easier. Also for converting many file layouts are available which may include options such as EML, EMLX, HTML, MSG, vCard, PST, and others. A trial version is also offered to each user to test the performance of the tool.
Read more - Convert Lotus Notes NSF to Outlook PST
