Free OST to PST Converter
Try free demo version of InQuit OST to PST Converter to convert 30 emails for free. With the help of this tool you can also see the preview of the conversion the conversion is done. This tool can help you to split the large sized PST files into small bits as per your needs. If you want to do the OST data conversion without any data loss then you should try this tool. You can also convert your data into various formats like PST,EML,MSG,vCal,vCard etc. This tool is one of the best solution for all the problems that are related to the OST data conversion.
Read More: inquitsoftware.com/en/ost-to-pst-converter
You can download the free demo version of the Cigati OST Converter Software that migrates the OST file into PST file format with all its attachments. This utility tool can securely import the emails, contacts, calendars, tasks, notes, journals, etc. from the OST file into Outlook PST format. This OST to PST Converter allows the users to convert normal as well as corrupt OST files into PST format.
