Found my 4 or 5 year old Sanse. I’m not sure if its really dead or just broken. Can somone help?
You need to give more information if you want people to help you. Did you try charging it?
Does it turn on? If yes, what do you see? Or does it get stuck on something? ![]()
if you have had it on the charger, maybe it has locked up. mine does that. just hold the power slider in the on position for about 30 seconds. then release and slide it quickly like you do to turn it on. it should come on. hope this helps
