Formatting
I tried using cmd to format the Scandisk cruzer blade 4gb when the format option in the dialogue when u right click the said drive couldnt help formatting… Please is there any other method i can use. thanks
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\Administrator>diskpart
Microsoft DiskPart version 6.1.7601
Copyright (C) 1999-2008 Microsoft Corporation.
On computer: ICT-PC
DISKPART> list disk
  Disk ###  Status         Size     Free     Dyn  Gpt
  Disk 0    Online          465 GB  1024 KB
  Disk 1    Online           64 MB      0 B
DISKPART> select disk 1
Disk 1 is now the selected disk.
DISKPART> clean
DiskPart succeeded in cleaning the disk.
DISKPART> create partition primary
No usable free extent could be found. It may be that there is insufficient
free space to create a partition at the specified size and offset. Specify
different size and offset values or don’t specify either to create the
maximum sized partition. It may be that the disk is partitioned using the MBR di
sk
partitioning format and the disk contains either 4 primary partitions, (no
more partitions may be created), or 3 primary partitions and one extended
partition, (only logical drives may be created).
DISKPART>
Try RMPrepUSB.
http://www.rmprepusb.com/tutorials/54—how-to-fix-write-protected-disks
To replace the drive:
http://kb.sandisk.com/app/answers/detail/a_id/5232/~/return-material-authorization-(rma)-process
yes, i have the same problem, anybody have solution???
Why are you trying to format the drive?
hi @itmichael I’m implementing the SD FAT32 file system without CPU involved so i took using 8GB SD card and i formatted as FAT32 and i check the FAT32 structure fields values
And again i took 16 GB SD card card and i did same which i done in 8GB card that time i got some fields values were different So could you please tell me how these values will vary wrt disk size and what is the calculation to calculate this?
Thanks And Regards,
Vinayak
