Formated my passport
Can I somehow to restore its initial partition with SmartWare? Downloaded “Disk Image” form support site but it’s just zip, neither image.
At the moment
  • i can’t use the disk at new computer because it hasn’t drivers
  • I can’t remove Virtual CD with Virtual CD Manager because it doesn’t recognize as SmartWare disk
What can I do with it?
Please follow this instructions :
Instructions on Recovering Smartware Installer
Thank you for your reply!!!
That is exactly that I did. My problem is at number 5: “Double click on WD Smartware.exe”.
After launching of the installer I received the message: “application not started from drive”…
… and after that installation aborted.
That’s not normal then. Have you try contacting WD?
To contact WD :
http://support.wdc.com/contact/index.asp?wdc_lang=en
