Format 1 tb Elements
I want to format a recently purchased 1tb Elements for use with my Macbook Pro running 10.6.8 which I thing is Snow Leopard. Any help as to how to do that would be appreciated.
Hi @MickyFig
The WD Elements drive you purchased should work fine for macOS once it’s reformatted. Please keep in mind that reformatting a drive will erase all data on the drive so please back up any data prior to following the instructions:
Hi, And thanks. But there isn’t anything for macOS 10.6.8, so which set of instructions do I use…if any?
We don’t support Snow Leopard anymore (it’s a really old OS), but if I recall it was very similar to the 10.7 instructions.
In general, to format a hard drive on macOS (10.6 older disk utility), you should:
  1. Connect hard drive to Mac
  2. Launch Disk Utility from Application << Utilities folder
  3. In Disk Utility, select your external 1 TB drive from the left panel
  4. Go to Erase tab
  5. Give a Format, Name and Size of the drive.
  6. Click Apply to save the settings
This should format your 1 TB external hard drive to your chosen Mac OS Journaled system.
You can open Disk Utility to format your 1TB Elements drive for Mac OS X 10.6.8 (Snow Leopard):
  • Connect the WD Elements drive.
  • Open Finder > Applications > Utilities.
  • Launch Disk Utility.
  • Select the top-level WD drive in the left sidebar.
  • Click the Partition tab at the top.
  • Change Volume Scheme to 1 Partition.
  • Set Format to Mac OS Extended (Journaled)
  • Click the Options… button below the partition diagram.
  • Select GUID Partition Table and click OK.
  • Click Apply in the bottom right.
  • Click Partition to confirm.
Here is a tip: Mac OS Extended (Journaled) is the most reliable format for Snow Leopard. Another newer format APFS does not exist in Snow Leopard and will not work. Also read: How to Format an External Hard Drive on Mac?
