For Mac Users: How to rip DVD and convert video to iPhone, iPod, Apple TV, Sansa, Walkman...
This guide will show you how to rip DVD and convert video to AVI, WMV, MP4, MKV, MOV, M4V, FLV, 3GP, 3G2, MPG, ASF, VOB and other video and audio formats for all sorts of mobile players such as iPhone, iPod, Apple TV, Sansa, Walkman, Archos, Zune, PSP, Xbox 360, PS3 with iMedia Converter for Mac.
Make Preparations: Download this DVD Video Converter for Mac(Intel Version, Power PC Version)
Step 1: Launch iMedia Converter for Mac and Add DVD or Videos
Click “Load DVD” button to load DVD or click “Add Video” to add videos.
After a DVD or video files are imported successfully, you will see all of them listed in the program:
User posted image
Step 2: Output Settings
This Mac DVD Video Converter can convert DVD movie and video to all popular formats for playback on iPod, Phone 3G, PSP, PS3, Cell Phone, Apple TV, Zune, Creative Zen, MP4 players and MP3 players and so on.
Choose the format from the format drop-down list before the conversion.
This converter has a list of optimized default setting for a series of players, so if you don’t know what formats your player supports, you can just select the format according to the device name.
User posted image
Choose the audio format (MP3, WAV, AC3, OGG, APE) if you just want to extract audio from videos on Mac and then specify a directory to save the output files. If you don’t want to use the default video and audio encoding settings, just click “Settings” button to customize settings.
User posted image
Step 3: Start Conversion
When you are ready to convert the added videos on Mac, Click “Convert” button to start conversion and you can choose to let the computer shut down automatically after conversion if you don’t want to wait around.
User posted image
Tips: How to edit the video files?
1. How to trim video clips?
Step 1: Tick the Check boxes of the video you want to trim, and click “Trim” button to open the Trim window below:
User posted image
Step 2: Drag the slider to set the starting time and ending time, and then click “OK”.
Note: You can preview the trimmed video clip before conversion in preview window.
2. How to crop video clips?
Step 1: Check the video you want to edit, and click “Crop” button to open the Crop window below:
User posted image
Step 2: Select an output aspect ratio and the available options are: Keep Original, Full Screen, 16:9 and 4:3.
You can enter the crop values manually or drag the rectangular selection frame round the video to select the displaying area.
3. How to merge several titles or chapters into one?
You’ll find “Merge into one file” at the bottom of the main interface, after you select the videos you want to rip and finish the output settings, you can tick the check box of " Merge into one file" to merge several titles or chapters into one.
Now you can enjoy your video files.
Here I also recommend you some Mac softwares: DVD Ripper for Mac, Video Converter for Mac, DVD Copy for Mac, DVD Creator for Mac, DVD to iPod Converter for Mac, iPhone Transfer for Mac, iPhone Ringtone Maker for Mac.
Maybe your name should read SimpleSimon!
Spammer! :angry:
