Folder View Question
I am using folder view as thats just where my albums showed up.
When viewing my “folders” on the CLUIP+, I first have to tell the CLIP+ if I want to view the folders on my Internal Memory; or view my other folders on my MICRO SD Card. Why does the folder view not integrate them during refresh?
I use folder view because thats wher my music shows up.
I loaded 10 albums into Internal memory, and then loaded 12 albums onto the Micro SD. I use MSC Mode. On my older CLIP I’d get 22 albums under Album View.
I would much rather view them all under Album View, but they are not there. If someone knows how to get them to show up there that would be great. But since I can only get to them in folder view I’d really like to have them be integrated together.
Someone mentioned that my album tags may not be correct. That may be right, but they were perfect for the regular Clip.
I had a similar reaction initially until I realized, this is precisely what the Clip should do under Folder view, showing the source for the various files, be they under whatever subfolder or folder or, higher up, the internal memory or external memory.  It helps to think of those locations along the lines of super-folders.
As to the viewing issue, have you double-checked to make sure that your music files are tagged, and correctly?
Good answer, yes I do understand.
RE: Tags
They were perfect for my regular CLIP
Why would the Clip+ not show them and the Regular Clip does?
It’s virtually the same 20 albums and now only 2 show up under album view.
Some things between the Clip and Clip+ may not be consistent.  And so I would just check to make sure that your other albums are correctly tagged (maybe the original Clip was more forgiving).  If there are issues with the tags (such as, missing tags), easy enough to fix them.
I’ll check
Thanks.
If they seem to be taggeg correctly, I’ll report back.
I checked the MP3 tags.
They are all there and saved.
I started over and loaded 10 albums.
I have 10 in Folder View.
It shows only 3 in Album view.
I am really disapointed.
I only bought the Clip Plus because of the Micro SD slot.
I guess I’ll get rid of the Clip Plus and get a second regular Clip.
Message Edited by glfnaz on 09-10-2009 05:10 PM
That is odd–something seems to be going on.  I would telephone SanDisk customer service for assistance.
Yeah and the really odd thing is that the Regular Clip always saw all the albums as Albums.
Do you think the firmware update will fix this?
Thanks for everyones help.
Are the files on the card in the music folder on the card? Perhaps if they aren’t, it might make a difference? If they are in the audiobook or podcast folder on the card, then they won’t show up in the music, albums list, but in the audiobook or podcast areas instead.
