Sansafix:
I’m a owner of a Sansa Fuze 8GB.
The quality and the sound is excelent.
I have the following question:
Is it possible to increase the FM Recording quality,-> sample rate 44 kHz (instead of 22 kHz).
If not, is it possible to implement this in the next Firmware-Update, or is there a technical limit?
A record option would be the best choice.
With the higher sample rate FM Recordings are possible without any quality losts.
I need this option, otherwise I must buy a second player (not a good solution),
but in every case I will use the Fuze in parallel (because it is the best player I ever had, thank SANSA for that)
Thanks you for your answer
