Brand new Clip. When I turn on the FM, it works for a split second then quits. It’s not the pause button, and not volume. It just quits on its own help!
Are you charged up? Leave it charging overnight and try it in the a.m.?
Same thing happened to my 2nd new clip… I don’t know if this will help or not but these are the steps I did to make all functions work properly.
Unplug clip from computer or charging source.
Perform a “reset” as outlined in the owners guide
Plug clip back into charging source, until battery is 100%
Unplug clip from charging source or computer.
Cycle it on and off (just to verify unit comes on properly)
Turn on and test all operations of the clip.
For me this did the trick. Hopefully, this or some variation will work for you… good luck!!!
Thanks for the detailed suggestion. We tried it, but it didn’t help. In frustration, and knowing our own technological limitations, we took it back to Best Buy. The techie looked at it and couldn’t make it work, so they gave us a replacement. The new one works just great. Again, thanks for taking the time to help out.
Glad to hear you could get an easy replacement! And, enjoy–
