Flashing SanDisk Extreme series SSDs (released around 2012)
SanDisk Extreme SSD (SDSSDX) R201 to R211: working method with no CD and no old PC
SanDisk SSD Toolkit says “Unable to look up new firmware update”, SanDisk Dashboard says R201 is the latest and only accepts .fluf files for manual firmware installation, and the R211 ISO won’t boot from USB. I got two SDSSDX480GG25 drives onto R211 this way.
1. Extract the firmware from the ISO
  • Download the R211 ISO for your exact capacity. Each capacity has its own firmware, so don’t mix them. Mine have 480 GB capacity. I downloaded the firmware ISO from https://drivers.softpedia.com/downloadTag/SanDisk+Extreme+SSD+Firmware.
  • Open the ISO in 7-Zip, then open RAMDISK.GZ, then open the cpio file inside it.
  • Extract firmware.bin. Check that the ModelPattern in fwspec.xml matches your model number exactly.
  • 480GB: firmware.bin is 453,632 bytes, SHA-256 c6516c7222d90aa9d7a5ef4a095b8a049d86ac2751f6b56799f7f8ee79b3db8e
2. Flash from an Ubuntu live USB
  • Connect the SSD to a SATA port on the motherboard, not a USB dock or enclosure. Set the BIOS SATA mode to AHCI.
  • Boot Ubuntu in “Try Ubuntu” mode from a USB thumb drive. hdparm is already installed. (Other linux should work, you just need ‘hdparm’ installed via sudo apt update && sudo apt install -y hdparm on Debian based systems.)
  • Find the drive: lsblk -o NAME,TRAN,MODEL,SERIAL,SIZE
  • Check it: sudo hdparm -I /dev/sdX | grep -i firmware
  • Flash it: sudo hdparm --fwdownload-mode7 firmware.bin --yes-i-know-what-i-am-doing --please-destroy-my-drive /dev/sdX
  • Power off completely, power back on, and check again.
What didn’t work
  • Plain --fwdownload (chunked mode 3): the drive rejected it with Illegal Request and stayed on R201, unharmed.
  • --fwdownload-mode7 through a USB enclosure: “Invalid argument”. Nothing reached the drive.
As always, flashing firmware can brick a drive, so back up first. I’ve only tested this on the 480GB model.
Hi @redfaern ,
(Get Support for Your SSDs and Flash Products | Sandisk)
Try this one.
If not, contact Sandisk Technical Support for assistance.
(Contact Support | Sandisk)
As per my post, I tried the SanDisk Dashboard software. It detected the drive, but said that the firmware installed (R201), was already at the latest version, which is simply incorrect. The latest version is R211 which fixes the SMART temperature reporting which affected one of my drives, among other things that improve perfomance.
It’s disappointing that Dashboard did not allow updating of the firmware for the 2x 480GB SanDisk Extreme series SSDs I had. It’s also disappointing that you didn’t appear to have read my post. My post explains how I flashed the firmware from Linux using hdparm so I fixed the problem myself.
