Flashing light and hardrive not appearing on my desktop
http://www.megaupload.com/?d=FMSNZUWK
^^ short video of what the lights doing, small file will take seconds to download.
Basically mybook won’t appear on my computer and the light is just flashing repeatedly as in the video. When I hold down the power button nothing happens it won’t turn off. Tried unplugging it, replugging it in different sockets etc - nothing.
This just happened one day when i turned it on. Very annoying as it had important files for my studies that i need to get at. Someone help please!
p.s if there is nothing I can do about it and mybooks just broken, is there a way i can get the files of of it?
I have same issue.  I upgraded firmware to version 2.010 then experienced the same symptoms.  Support services recommended attempting upgrade using Windows OS.   No luck, same symptoms.  I consider the drive dead.
