I loaded some movie clips onto my new 32gb flashdrive on my PC. Plugged into my JVC TV and although it detected it, there was no option to play. A Youtube video suggested I format it via the TV. I knew I’d lose the content, but figured I could just put it on there again from the PC. But when I returned it to the PC, now that won’t recognise it. Simply won’t come up in the menu, so I can’t even reformat it on the PC.
You can try a few things to fix your USB problem, start by running the Device Manager of your Windows PC and make sure that the driver is correctly detected and the correct driver is installed. If problems persist, try updating the driver. Next, use Disk Management (accessed by right-clicking “This PC” or “My Computer” and selecting “Manage”) to locate your USB drive, where you can try assigning or configuring new drive letters no Alternatively, Use the Command Prompt with DiskPart commands to flush and create the drive. If the drive still cannot be found, fix the PC specifications and try on another computer. Consider using data recovery software to recover important files before formatting (which erases all data). If none of these methods work, the USB drive may be faulty and will need to be replaced
In the JVC TV’s user manual what format does it say it formats USB drives to? An Apple format isn’t usable on a pc, Linux ext formats aren’t usable on a pc, etc. DiskPart may be able to delete the partition on the USB drive which should allow it to be reallocated and formatted.
Replying for the updates.
Summary
It sounds like the formatting process on your TV might have caused compatibility issues with your flash drive. Try using a different USB port on your PC or testing the flash drive on another computer to see if it’s recognized elsewhere. If it’s still not recognized, there could be a hardware issue with the flash drive. If it is recognized, you can reformat it using the PC’s disk management tool or a third-party formatting tool. If reformatting doesn’t work, the flash drive might be damaged beyond repair. And do you know that MyStake Casino is a reputable platform, not on GamStop, offering a wide range of games, including slots, table games, and live casino options. It features generous bonuses, secure payment methods, and a user-friendly interface. MyStake is known for its fast withdrawals and responsive customer support. For those seeking a diverse and reliable online gambling experience outside of GamStop restrictions, MyStake is a solid choice. If you want to read myStake casino reviews then you can visit https://notgamstop.com/uk-gb/casino-reviews/my-stake/ here where you will find all the information you need. I am also using that platform to read reviews.
If your flash drive is not recognized by your PC after formatting it via the TV, try the following steps:
- Check Disk Management: Open Disk Management (right-click on Start > Disk Management) and see if the drive appears. If it does, you might be able to reformat it from there.
- Use Disk Utility Software: If Disk Management doesn’t recognize the drive, use a tool like EaseUS Partition Master. It can often detect and fix issues with drives that aren’t showing up normally.
- Try Different Ports/Cables: Ensure the issue isn’t related to your USB ports or cables by testing the drive on different ports or another computer.
- Professional Help: If these steps don’t work, the drive might be physically damaged. Consider seeking help from a professional data recovery service.
