Fixing clip+ stereo jack
Hello!
I broke my clip+ so the left audi channel kept disconnecting.
after a while i had enough and pried open the back part of the player (quite easy)
thats what it looked like inside
then i noticed that the jack is pretty solid and connects to the plugs tip pretty well.
instead one of the 3 soldered connections had came loose
thats wat needed soldering.
Oh, and remove micro st card before opening it up (if u feel like u need to do the same thing)
Great photo!  I had a feeling that the lower right one was the trouble maker.
Bob  :smileyvery-happy:
